Is there a way to put connected sessions at the top?
Is there an option to put connected sessions at the top of the tree view, like RDPman used to?
This is not something supported unfortunately. Could you explain me why it's useful for you to change the order?
I have a large number of sessions saved, but usually I am only working on 4 or 5 servers at a time. However, these servers aren't necessarily going to start with the same letter, so I am always scrolling up and down the list when I switch between them.
I currently have sessions grouped by domain, and I know I could put subgroups under that, but there isn't really any sensible grouping I could make there.
I used to use RDPman, which would list connected machines, followed by unconnected ones (within each group), so I only had to scroll when connecting to a new server. It would really help to have that option in RDM.
I'm not sure how easy this will be but I have created a feature request for that (I know it look simple but the tree is not aware of the opened connection to execute the sort). In the meantime you can click View | Tab Groups and dock it somewhere else to view your opened connections.
