RDM - Right way of using the "Use multiple monitors for the remote session" RDP option
I tried to figure this out empirically and using the documentation (in that order, of course :D), however I didn't manage to come to stable conclusion.
What I try to achieve:
Having 3 monitors (laptop + 2 external), I'd like to be able to establish an RDP connection using only the two external monitors while having the laptop one as "local". In Windows display settings I see that my external monitors are numbered as 2 and 3 (the laptop is marked as 1).
What I did so far:
I set up the session properties as seen on the screenshot attached. However, the RDP session only opens on my primary monitor. If I select from the "Use multiple monitors for the remote session" dropdown the option All (without any other options changed from what you see on the screenshot), I do get RDP to open on my three monitors.
All that being said, I would like to understand what is the right way of having RDP to open on several specific monitors of all the monitors currently plugged in to my local machine. I saw this question in the forum several times but nothing conclusive, so far.
Thanks in advance!
We are aware of this issue and it's on our todo list. We'll increase it's priority to get it fixed as soon as possible.
In the meantime, here's what you could do as a workaround :
Export your entry as a .rdp file
Create another RDP entry in "Embedded RDP File" mode and import your previously exported .rdp
Add/Modify the line "winposstr" to match your screen sizes. For example, on a 2 monitor setup (first 1920x1080, second 1600x900), here's what it would look like if you wanted to place it on the second monitor : winposstr:s:0,1,1920,0,3520,0. You can learn more about the different parameters here : https://social.technet.microsoft.com/wiki/contents/articles/665.how-to-set-the-monitor-for-a-remote-desktop-session-in-a-multi-monitor-setup.aspx
Hope this works for you while we work on resolving this issue.
Jonathan Del Signore
Hi Jonathan,
As always, thanks for the prompt reply! I will be able to test it in a couple of days and will come back to you. I guess it will suffice, since you’re proposing it.
Thanks again and regards!
