The shortcut to move between connected hosts on a Mac (Command-Shift-[Left|Right]Arrow) switches desktops when editing entries instead of letting you move the cursor as you normally can on a Mac.
To reproduce, edit a host. Put the cursor in a text box (Name) and then press Command-Shift-Left, which should highlight all to the left. If you have multiple desktops open, it cycles between them instead.
You can change (or remove) the shortcuts for the Select Previous/Next Tab menu items in the Preferences -> User Interface -> Shortcuts panel:
This should solve you issue.
Xavier Fortin
Hi again,
I've also fixed it so the tab navigation shortcuts are inactive if a sheet is embedded in the window (e.g. entry settings view).
This will be available in the next release.
Xavier Fortin
that's the answer I was looking for and expecting from such a great product. thank you!
Glad to hear it!
Do not hesitate if you have any other issues.
Xavier Fortin
Hi kknopp,
The version 2021.1.3.0 just got released. The Select Next/Previous Tab shortcuts should now be inactive when a sheets is shown over the Main Window (or over and undocked window).
Xavier Fortin
Installed and tested. All good now. thank you!
Hi kknopp,
Glad to hear it!
Xavier Fortin
