Custom Username Script not executed
I'm trying to get the custom script under username to run, but the script is not beeing executed.
What I'm missing?
Thank you
Harald
All Comments (4)
What RDM Free version are you using?
What browser is used to open this entry?
Does the script fail to run in embedded or external mode?
Érica Poirier
Version: 2021.1.21.0 64-Bit
Google Chrome
The Script does not run on embedded nor on external.
Thank you
Thank you for the information.
Could you please try without the HTML <script> </script> tags? The code should be Javascript only.
Érica Poirier
I tried that as well, did not work.
Thank you
Harald
