Microsoft Edge - Problems with login data
I created a web session for my router and a credential entry from Bitwarden linked to that web session. I ran a discovery for the login fields which was successful.
For some reason, running the web session leads to a failed login each time. It's not a credential issue, if I click on the key symbol in the toolbar, the credentials are filled in fine and I can log in.
I tried increasing the "autofill delay" to 1000ms and I removed the check in front "Auto Submit". The latter doesn't have to have any effect, it's always submitted automatically, and fails.
I then changed the browser to Google Chrome, otherwise not changing any settings. This worked right from the start.
All Comments (1)
Thank you for contacting us on this matter!
In order to investigate this behavior, we would need to be able to replicate it internally. Could you please let us know if you are able to get this same behavior using a public webpage, and if so which one? Being able to so tests on a page where the issue occurs would greatly help us locate the cause of this issue.
Gabriel Degrandpré
