I see in the changelog that in version 2020.3.1.0 "Added external mode to SSH Shell session with choice between using Terminal or iTerm2" but I cannot find any option to change the external terminal application RDM launches SSH sessions in. Open (External) launches in the regular terminal.
Hi ajclarke
To switch between Terminal and iTerm2 you need to go into preferences > types > Terminal
then find the box labeled External. There you will have the choice to switch between Terminal and iTerm2 for your external mode.
I hope this help you.
Michel Lambert
