remote desktop manager does not minimze to tray
Hi.
Thank you for Remote Desktop Manager 5.6.3.0
I am running on Windows XP 64-bit.
RDM is setup to autorun when windows starts, start minimized, not always show in taskbar, and reduce to tray icon on close.
When windows starts (I log in from a fresh boot), Remote Desktop Manager is minimzed in the taskbar.
However, when I click the window on the taskbar, it opens, but when I click the minimize button, it does not minimze to the tray. If I click the close button, it does nothing.
The only work-around I found was to right-click on the tray icon, select Restore, and then I am able to click on the minimize and close buttons from that point and thereafter without issues.
Thank you.
All Comments (1)
I will come back to you soon, I'm currently rewriting this part. Thank you
Devolutions inc.
