Center dialogs on application window, not monitor
Implemented
When dialog boxes from the application popup (verify logout for example), it would be handy if they were centered on the main application window instead of the whole monitor.
This is especially useful for ultra-widescreen monitors, where you might have an RDM window sized to the left half or third of the screen. Dialogs popping up in the middle of the monitor are often not where your eyes are focusing.
I looked and didn't see anything that performs this function, but forgive me if I missing something obvious. Thanks.
All Comments (2)
As you said I don't think it's possible at the moment, but it's an interesting change and I understand why it would be very useful. I've opened a ticket to take a look at this improvement and see if we can change it or make an option for it.
As a note, at the moment RDM should remember the last place you closed a window (provided it wasn't canceled) so that it can reopen it at that spot in the future.
We've added a Center Windows on Parent option. This will be located in the Options - User Interface - General section and should be available as early as next version.
Jafran Majeau
