Quick connect with default settings
Hello everyone
Maybe someone of you can help me. Is there a way to apply some default settings to the Quick Connect feature?
I often use quick connect to connect to computers, but I would like to make sure, that my local drives are never mapped into the remote session.
I did search around the settings, but did not find a way to apply such defaults.
Also it would be amazing, if this defaults to not map local drives could be applied globally within RDM on a per-user base.
All Comments (2)
You can apply your own templates when using Quick Connect: https://kb.devolutions.net/rdm_quick_connect.html?q=template#using-templates
This way, you can disable the mapping of local drives and change any other settings as needed.
You can see what your current selection is for the Quick Connect at the bottom of RDM:
For more information on templates: https://help.remotedesktopmanager.com/commands_creatingtemplates.html
Richard Boisvert
Thanks a lot for this fast reply. Seems that I did not search enough for that feature... Amazing.
One of the reasons, why I love RDM so much.
