Cross Vault Credential Usage
Can you please add the ability to use credentials from another vault (not the user vault) to login to a RDP session. For example The account login credential is in a Vault named “Credential” and the RDP session entry is in a vault named “DC1” Currently when you right to assign a credential override, you only seem to have an option for the current vault the RDP session is in, or my user vault. This is the same when you try to connect to it with “Open (Select Credentials)”
Another way of doing this would be to create a method of linking a user vault credential with credential in another vault (like a favorite or a shortcut) this would mean the credential could be used from the private vault, but could update and cache a new password if the credential was updated.
All Comments (11)
Thank you for the suggestion.
With our current version (v2020.3) the vault architecture does not support this type of feature. We are changing the internal architecture of vaults with the soon to be released version 2021.1. In the future this type of feature could be possible. I will add your suggestion to our list so that we can investigate its feasibility.
Stéfane Lavergne
+1 for this feature request. Would help us a lot.
is there any update on this feature request or probably a roadmap/timeline for it?
Best regards
Hi all,
I’m currently working on this feature and have just over three weeks to deliver it for inclusion in the 2025.1 release. At this time, it’s still too soon to say for certain whether I’ll be able to complete everything needed on time.
Reflecting on my earlier comment, it’s hard to believe this feature was first requested four years ago—how time flies! With the release of 2024.3, we made significant progress, including enabling background vault synchronization, which was a critical stepping stone toward cross-vault credential linking.
Currently, I’m focused on rewriting and validating the variable-resolving code. This is essential for allowing RDM to isolate each vault so that variables can be resolved independently, without cross-vault contamination. I’ll also need to apply the same changes across each subsystem in RDM (permissions, inheritance, etc.).
I’ll provide another update once the feature is released.
Stéfane Lavergne
Hi all,
Hi Stéfane,
I was searching for cross vault linking in my case cross vault credential linking, then came accross this post, I see you were working on something for a 2025.1.x release, did it happen?? If so exaclty what was it, I see you mention variables but will your addition / change work for my scenario?? Granted I mainly use my personal vault or now PAM vaults for most credentials, but as you can tell I've come accross the need to use Credential entries from another vault but have been hitting a road block on how to proceed, I initially looked for an entry that could link cross vaults but couldnt find anything, then I started to look if Syncronizers could work, which then led me to consider just scripting this (This is similar to another problem ive not succeeded with which is propergation scripts for PAM vault creds). Anyway, would what your working on work for my scenario, has it released yet (soz yet to search through rls notes)
JK
Devolutions Force Member (and Long time Devolutions Fan)
Hi all,
Hi Stéfane,
Scrap my previous I've just answered my own question DOH!!
This entry did the job...
JK
