When connecting to Server 2019 with RDP it signs out just as the desktop should load
In order to help me determine what could be causing this issue, I have a few questions about your RDM environment :
What version of RDM do you currently use?
What is the type of data source you use?
Is your RDP session set to the Embedded or External display mode?
Are you able to connect to the same remote server using mstsc instead of RDM?
Gabriel Degrandpré
After having tried from RDM with external mstsc started having the same issue with that one server.
RDM version 2020.3.29.0
Local data source db v 1.132
Looks like it was some cached domain thing....
Clear remote desktop cache and now it is working.
Thank you for your response! Glad the issue is now resolved!
Don't hesitate to contact us again if you have any other questions!
Gabriel Degrandpré
