Entry description in RTF format not showing in dashboard
Hi!
I have a question about the possibility to use RTF formatting in the description field in RDM. I can add RTF in the field but it is not showing in the dashboard. Is that how it is meant to be? The only way to view the RTF is to go into properties of the entry?
forum image
All Comments (2)
Unfortunately that's a technical limitation that we have. That's why we no longer recommend to use the RTF in the description. We are not able to display it with the formatting in the overview. Have you tried to use the documentation with the markdown instead?
Hello David,
Ok, I understand. We will go for another solution. Probably markdown in Documentation tab or maybe use the confluence tab to an external system.
regards
Andreas
Closed
