I have an encrypted vault with a password and Yubico YubiKey OTP which both get prompted and accepted but afterwards the application hangs, doesn't respond to UI interaction and doesn't display the vault. I was using the beta version but I have downgraded to the latest stable and the problem persists. Any ideas what to do from here?
Weird, it started working after a while.
Glad that it is now working, do not hesitate to contact us back if the issue occurs again!
Best Regards,
Etienne Lord
Well even though it works now the <enter> key is not forwarded into the remote session and I can no longer use it because of this. Other keystrokes work and the enter key works in any other application locally and through the regular remote desktop application. Any ideas what could be the problem? I have tried restarting the app.
-Paul
The issue has been fixed internally, it will be available in the next release of Remote Desktop Manager :)
Best Regards,
Etienne Lord
For the time being, if your uncheck this option (magnet), it should work normally :
Best Regards,
Etienne Lord
Awesome, thank you!
