2020.3.21.0 Navigation pane capturing keystrokes (enter)
Implemented
I just upgraded to 2020.3.21.0 and have an odd bug. After opening a session pressing enter appears to apply to whatever was highlighted in the navigation pane, even though the you're typing in the session. So if you have the current session highlighted it does nothing, because the session is already open. If you have moved what is highlighted do a folder, you'll get a prompt to open all session in the folder. The problem does not seem to be session type specific, I have tested it with both ssh and rdp sessions. As well it does not appear to matter the data source, I have tested it with Local, Password Hub Personal and Password Hub Business. I have found that sometimes changing to another data source, other than the one associated with the session, will allow you to use enter in the session, but it is a bit hit or miss.
Thanks.
David
All Comments (2)
Hello David,
The engineering team is currently aware of the issue and have a high priority ticket to implement a fix. In the meantime, you can either disable the magnet in the bottom right corner of the RDM application or downgrade to 2020.3.19.
For more information on the grab input (magnet):
https://help.remotedesktopmanager.com/keyboard_grabinput.html
For the enterprise version: https://cdn.devolutions.net/download/Setup.RemoteDesktopManager.2020.3.19.0.msi
For the free version: https://cdn.devolutions.net/download/Setup.RemoteDesktopManagerFree.2020.3.19.0.msi
Richard Boisvert
A fix was pushed this morning for the <Enter> issue. You can either install the latest version directly from RDM or download it from our website.
Enterprise edition: https://cdn.devolutions.net/download/Setup.RemoteDesktopManager.2020.3.23.0.exe
Free edition: https://cdn.devolutions.net/download/Setup.RemoteDesktopManagerFree.2020.3.23.0.exe
Richard Boisvert
