Multiple Session connection options per Entry
We're looking for a way to have a single Entry in our Data Source list, but with multiple connection options. An example would be a server entry, but the ability to connect to that server via RDP, SSH, or VMWare console without having to have multiple entries for each connection type. Possibly have a default connection type so when you double-click it connects via RDP, but right-click you have the option of RDP, SSH, or VMware console. Something like that.
All Comments (1)
In order to achieve this, I would recommend that you opt for one of these scenarios:
1- Create a Template under File -> Templates and add it under the Macro/Script/Tool section of your Dashboard. This method will allow you to quickly select the entry you created in your Navigation pane, then go under the Macro/Script/Tool section of your Dashboard to apply the Template on the connection and launch it with these settings.
To do so, please refer to this link: https://kb.devolutions.net/rdm_add_a_template_as_a_custom_tool.html
2- Create a Template with the desired setting, select the entry you created in your Navigation Pane, right-click on it and use the "Open with Parameter "-> "Open with Template" feature:
Doing so, will allow you to select the Template you created under File -> Templates -> Manage Templates.
James Lafleur
