Remote Desktop Manager Addons and Components?
Hello!
The Remote Desktop Manager application does not allow using Microsoft VPN, SSHTunnel and other types of connections when connecting (seen in the photo). At the same time, I installed the entire application from the developer Devolutions from the Play Market, but the application still gives an error: This mode is not supported. How to install modules to support these modes ?! What should be done?!
Tell me please!
P.S: OS Android 10.0
Although this application supports a lot of features, it doesn't support as many features as our main application (Remote Desktop Manager Windows). Sometimes, the features just aren't implemented yet and sometimes it's just not possible to implement them on mobile platforms (like opening VPNs automatically). Regarding VPNs, the corresponding apps (when available) need to be installed on your device and we simply cannot open them from our app. Our data can be shared across multiple platforms (RDM Windows, RDM Mac, RDM Linux, RDM Android, RDM IOS)/devices and that is why the VPN configuration is visible on RDM Android even if it cannot be automatically opened at the moment. We support many session types: RDP, ARD, VNC, SSH Tunnel, FTP, SCP, SSH, Google Drive, Microsoft One Drive, SSH Port Forward, Telnet, etc.... If you need to be connected to a VPN before you open a session, you will have to open it manually beforehand. As for SSH to automatically open before opening a session, it has not been implemented yet on RDM Android.
Best Regards
Nicolas Dufour
Hi!
That is, it turns out that Remote Desktop Manager Windows, Remote Desktop Manager Linux and Remote Desktop Manager Android are not different applications, but one cross-platform application and connection data can be transferred between platforms.
If so, thanks for your answer.
Best Regards
Yes that's it. The information can be shared across devices/platforms. RDM Windows will support all the features whereas other platforms like RDM Android will support a subset of those features (sometimes a specific feature cannot be supported on the platform and sometimes it just hasn't been implemented).
Best Regards,
Nicolas Dufour
