Problems with license change
Hi Devolutions
Our old license expired and we've added the new one under Administration -> Licenses.
When opening Licenses now we have the expired license, an active license with 12 users and an active license with 6 users.
All users have been assigned to the new licenses and yet we still seem to be on the old one, even after a refresh.
Trying to remove the old license seems to work, until we interact with RDM then we get the attached message and the old expired license reappears in the Licenses window.
What are we doing wrong and how do we fix it?
We're running RDM Enterprise edition 2020.3.16.0 64-BIT
- River
All Comments (10)
This is odd. If you go into Help > Register Product what option is selected? You should be set to "User registration from data source" with your data source selected. If not select it. Regardless of what is was before, please close RDM and open it again to see if that resolves the issue.
It looks like RDM is having an issue while toggling from the old licensing format to the new one. We will need to investigate, in the meantime, I'm hoping a restart will act as a workaround.
Stéfane Lavergne
