View->Layout->Footer->Description pane does not display descriptions on folders.
I have descriptions on some folders with usage instructions on what sorts of sessions belong in the folder. I notice today when I started looked at the description pane, that only actual sessions show descriptions, If I click on the folder and navigate to Overview. I can see the description, but nothing in the description pane in the side bar.
All Comments (1)
In order to see the description of your Folder in this section, you will need to make sure to check the "Show folder details/description" at the bottom left corner of your Dashboard:
That being said, I will now move this forum to the "Support" section of our forum.
James Lafleur
