Problem with multiple instances of WinSCP and key-based authentication
When using WinSCP with key-based auth it's not possible to have multiple instances open. It seems that, when you try to open the second instance, the temp file with the private key is not correctly generated. Then WinSCP gives back an auth error. See the video for further details.
