Every connection requires a Lastpass vault password
bhubbs
Disabled
Used to be that once the Lastpass vault was logged into it stayed that way for the entire RDM session. I'd like to change it back to that.
All Comments (1)
Thank you for contacting us on that matter! You will find the different options regarding our LastPass integration under File > Options > Types > Credentials.
If you wish to have the exact behavior you had in previous versions of RDM, you can check the "Use legacy connection mode" option.
Gabriel Degrandpré
