Multi Vault Advanced Search - Add Description Search
Implemented
vogl
Disabled
When searching a single Vault using the Advanced Search option, there are a number of fields that can be searched, however when searching using the Multivault Advanced Search there are only a small number of fields to search.
The primary field that I would like to see added is the ability to search the description field across multiple vaults. The other option would be to allow a search using a custom field, which we can then utilize.
This is not as simple as it look. Unfortunately most of the data is encrypted and only few fields are available for the multi vault search. Those fields are part of the metadata. I'm not sure why the Description is not available and I will check.
vogl
Disabled
Thank you, If the description field cannot be used, then it would be great to have a Custom Field search, if possible.
We have created a improvement ticket for at least the Description. I think that we should be able to add this for the next major release of RDM.
