Using Bloomberg terminal with Anydesk
memorytron
Disabled
Does anyone have the following issue?
After using Anydesk to access to Bloomberg terminal in another computer, and returned back to your main computer, the Bloomberg terminal will automatically generate a print and save destination box, which is quite disturbing. Does anyone have any idea on this? Thanks.
That being said, would it be possible for you to go under the Help section of RDM's ribbon and use the "Submit a support ticket" option to open a support case with us?
Through it I will provide you a secure link in order for you to be able to give us a recording of this issue, This information will give us a better understanding of this behavior.
Just make sure to mention the URL of this forum thread in your ticket.
James Lafleur
Hi, thank you for your guidance. Do I have to install any software to ask the question because I saw that RDM has certain kinds of instalment listed. Thanks.
There is no need to install a software to ask a question, here is an example of what you should see:
forum image
Christine Breault
