Desktop shortcut for Credential entries
I have a Passportal credential entry and often times I would click on "View Passwords" and filter by the clients/companies and then find the username & password that I need. It is faster than doing it through the Passportal website (the official method).
I would like to improve on this process further, by creating a desktop shortcut to directly access the "View Password" function of this credential entry.
I'm always using the latest beta RDM x64 version.
Local data source.
All Comments (5)
I didn't tried yet but I think that you can replace the action "Find" by "View" and this should work fine.
Sorry, I'm not sure what you mean? There isn't a "Find" or "View" parameter in the desktop shortcut commandline.
All I'm trying to do is create a desktop shortcut:
And when I launch the shortcut, it will let me "View Password":
Local data source.
Hello Chaos,
In order to do this, you will need to go in the properties of your Passportal entry, under "Entry Information" and use the "Create Web URL" button:
Then head over to your Web Browser to paste the URL that has been copied to your clipboard and replace "open" for "view":
The URL should look similar to this:
rdm://view?DataSource=2C4AD1FC-C19B-4850-BE80-74B0F6CA476B&Repository=00000000-0000-0000-0000-000000000000&Session=e9f1e34f-25b1-4bec-bc46-54a765d2f593
Then copy this URL right-click on your Desktop -> New -> Shortcut, paste the URL in the "Type the location of the item" field, press on "Next"-> Type in a name -> Finish.
In doing so, a shortcut will be created. This shortcut will allow you to open RDM and view the password contained in your Passportal entry.
James Lafleur
Thanks, that worked. I was using create desktop shortcut instead of create web url, so I think that's what the issue was.
Local data source.
Hello Chaos,
I am glad to see that this worked for you!
Do not hesitate to contact us again if you require further assistance.
James Lafleur
