Any way to define a base configuration and then it prompts me for server name?
We have an environment where to RDP into a Windows server we have to go through CyberArk first and this requires a fixed "host' name but under 'Programs' starting a program on the connection and it is here that the actual server to connect to is specified.
Since I'm logging into many different servers on a daily basis, it would be nice to be able to setup a configuration where when run it prompts me for the server name and that value is then replaced in any string in the configuration where something like %SERVER% (or other key) is found.
Currently I find myself 'duplicating' existing entries and then editing the server name and 'Programs' and ts works, but it adds more work since I have to create an entry, log in, then delete the entry when done since my connections are most often one-time connections.
Is this possible? If not, I'll add this to an enhancement request.
There's already a ticket opened to our engineering department regarding this.
The ticket number is RDMW-1077.
Thank you for your post by the way!
Thank you. Look forward to this new feature.
We've added an option in the before open events to prompt for the value of a variable.
The value you enter when prompted will be saved in the variable $PROMPT_VARIABLE$, which you can then use as long as the session in opened.
This feature will be available in version 2020.3.9.0.
Jonathan Del Signore
