Implemented
FortiClient SSL Connection
Hey everybody,
first, I wanna say thank you for that amazing tool ! I really appreciate it.
I wanna create a VPN connection to our Fortigate. We have multiple VPNs configured there, but im running into trouble to always connection only to the default VPN gateway.
After some testing I found, that there is no way to define a sub-vpn, cause I could only set the Host, not the VPN Path like in the FortiClient.
i.e:
Our server is like https://vpn.server.com, so far so good.
When I have multiple VPNs on this server, the second one will be: https://vpn.server.com/thesecondvpn
So it looks like a subfolder. Which works fine in FortiClient. But I can not add it as a host, cause it wil create the following: https://vpn.server.com/thesecondvpn:443 instread of https://vpn.server.com:443/thesecondvpn.
Maybe you have some advice or idea to fix this. Thanks !
Warm regards
Florian Dahn
PS: Sure I could just create the command line on my own, but this addon is easier and more maintainable. :-)
Thank you for your post.
This should be easy to fix by our engineering department. I opened a ticket for them.
The ticket number is RDMW-5621.
Just to let you know, the fix has been made internally. This should be available once RDM 2020.2.17.0 releases.
Hey,
ok great, waiting for the update :-)
Warm regards
Florian Dahn
