Resolved
RDP Drag and drop possible?
is there a way to enable drag and drop for rdp tabs?
All Comments (4)
I have been able to reproduce this behavior and we do not have an option to enable this.
That being said, a ticket on that matter has been assigned to our Engineering Department in order to see what can be done.
I will be in touch shortly!
James Lafleur
just to be clear since i didn't write it very well.
I mean dragging and dropping files into the RDP remote computer work area
not dragging tabs around
Thank you for the clarification!
That being said, this is also what I though you were referring to.
James Lafleur
Our Engineering Department just informed me that this issue is a limitation of the RDP ActiveX we are using to launch embedded connections in RDM.
Unfortunately, this is not something that we can change on our end since we have no control over Microsoft's ActiveX.
James Lafleur
