RDMFree High CPU Load and random Freezes
Processor AMD Ryzen 7 2700X (8 core) 4.15Ghz
Windows 10 Pro
Version 2004
OS Build 19041.329
Experience Windows Feature Experience Pack 120.2202.130.0
RDM runs with up 25% CPU and for no reason i can tell will just freeze.
I've looked at the logs there is nothing in there except the connections Info. There is also no crash detail . the only recovery is to force RDM to close via task manager.
I Just saw a thread on using RDPFree as the type so i've switched over to that. So far the CPU usage is back down to 10% (which is more inline with what i expected) but I'll have to wait and see if the app locks up again.
Screenshot of my typical RDM setup and task manager usage are attached.
Indeed, RDP sessions could consume a lot of memory when several are launched at the same time while using the Microsoft ActiveX to establish the connection.
Let us know if you encounter the same issue using FreeRDP.
You can also try to close the thumbnail if you don't use it. This consume some CPU to generate it.
Thanks for the replies.
So far i haven't seen the same behaviors from RDPFree. I can significantly reduce the CPU load on my host machine if i change the refresh in the NetData VMs (which is odd) but, I think my original issue of RDMF freezing up kinda got lost.
Is anyone else seeing that behavior? or is my use cas the only one?
