Documentation Hard to Read When Using Theme Dark Gray
Implemented
after upgrading RDM to the latest version (2020.2.14.0 Enterprise), the embedded documentation is a bit hard to read when using the theme "dark grey":
Is there anything I can do about that? E.g. change the font color to black?
Best Regards
All Comments (4)
Indeed it's hard to read and it's easy to fix. We wil update this for the next minor release.
Thanks for the quick answer. This sounds great. Is there a time frame for the next minor update?
Best Regards
it should be early next week if everything goes well.
Wow, great!
I am looking forward to the release.
Best Regards
