Hello
My data source is some xml file stored on a network drive. In case the network drive is not available, RDM backs up this file locally as well. Unfortunately sometimes the way I find out the network drive is not available is by trying to connect to the network drive file. RDM wipes my local backup completely, RDM knows it has not connected to the file, but it wipes my backup as if the list is empty.
Does anyone have a solution to this problem?
Thanks you !
Is there a reason why the XML is saved on a network drive and not locally on your workstation?
