ability to make property menus part of 'advanced mode' or not
Implemented
With the release of 2020.2.12.0 when you right click an entry and go to 'properties' there is now a new slimmed down set of pages on the left and a toggle at the bottom for 'advanced mode'.
We would like the ability to choose what pages are part of advanced mode or not. For example, it seems the 'assets' page has now been moved to advanced mode. We would like the assets page to not be behind the advanced mode toggle, but instead be part of 'simple mode?'
All Comments (5)
Thank you for your suggestion. It's a good idea.
Support for customizable Advanced UI menus has been added. It will be available in version 2020.2.16.0 in File -> Options -> User Interface -> Advanced.
Jonathan Del Signore
Thanks for adding customizable menus!
It would be nice if it will be possible to add also menus from Management Tools.
For example, we'd like to add the Home Page menu to the simple menu mode.
Best regards.
We'll open an additional ticket for the values under management tools.
We've added the management tools menus to the customizable list. It will be available in version 2020.3.
