Webpage do not auto login with 'External' as display.
If I open the application, the username and password are auto filled and auto-logged in.
Where as if I use 'External' as display, the application opens but username and Password are not auto-filled.
Even if IE remembers the credentials, Auto-login does not happen.
See the attachment.
All Comments (10)
To send the credentials to a website in external mode, you would need to install one of our browser extension + enable the enable web browser extension link option located under the Advanced tab in the properties of your session.
Our browser extensions can be found here
https://devolutions.net/web-login
Small precision, we do not support IE in external mode, so you would need to use another browser like Chrome or Firefox as example.
You would need to change the browser inside your session as well.
