Prohibit editing Default Settings for Entry Templates
Implemented
Since there currently is no option to prohibit access for users to the Default Settings to edit Entry Templates, I'll be submitting a feature request because this would be a really nice feature.
We would like to see the possibility where this section can be blocked with either a GPO (.admx) or through the Data Source System Settings.
Thanks!
All Comments (6)
I will add this to our todo list.
The feature will be added in the System Settings. You can find it under Applications in the General section, it will be named Disable default templates editing and will prevent any non-admin users from accessing the default templates located in the screenshot you provided. This should be available for next version (2020.2.5).
Jafran Majeau
Thanks for the update, I'll be looking forward to this new feature.
Kind regards,
Tim
DLA ICT
