As subject, I've tried autofill settings but iDRAC9 login page is shown with empty controls.
Thanks.
Could you try the option Use legacy control IDs, I think this option works for iDrac 6 and 9.
David Grandolfo
Nope, doesn't work!
Thanks for the test,
Could you open the iDrac9 web page with an external browser and send me the Page source at Ticket@devolutions.net
I will then look with the engineering department.
David Grandolfo
Sent.
Just for your knowledge, with a standard web page entry there are issues binding "submit" action because, I suppose, login button has no ID so I can't map it.
Thanks.
