Looking at the application going forward as a permanent app for using RDP to multiple servers.
However when you add a new connection and open the RDP session it auto logs you in with the local account and does not prompt you to login.
Am i missing something?
In order to be prompted for credential already stored in RDM upon launching your RDP connection, you will need to make sure to use the "Prompt on Connection" option:
On the other hand, if you wish to be prompted to type in your credentials, you can leave the credential mode to "Default" and leave the Username,Password and Domain fields empty. Just make sure to uncheck the "Store password locally" option as well
James Lafleur
