Suddenly the window location of RDM opens to the top left corner of my screen, whereas it used to open where I had it positioned in the center. The application start window state setting is set to "Last Saved".
Setting it to maximized works, but I can't get it to now stay where it was located.
In the RemoteDesktopManager.ext file, the placement values are showing this below. I'm thinking the negative values for Left/Top are positioning it off the screen?
<Placement>
<Value><?xml version="1.0" encoding="utf-8"?><WindowPlacement><length>44</length><flags>0</flags><showCmd>1</showCmd><minPosition><X>-1</X><Y>-1</Y></minPosition><maxPosition><X>-1</X><Y>-1</Y></maxPosition><normalPosition><Left>-10000</Left><Top>-10000</Top><Right>-8341</Right><Bottom>-8901</Bottom></normalPosition></WindowPlacement></Value>
</Placement>
Oh, and I did try Resetting the layout for all options, it did not fix.
if you rename the remotedesktopmanager.ext into remotedesktopmanager.old and restart RDM, does it help?
Doing this will reset your .ext file.
Let me know of the results.
Yes, that appears to have fixed the problem.
Thanks much.
Glad that we have been able to get this solved!
Have a nice day!
