Go Offline On Connect for Websites
we are using several VPN web portals to support our customers.
Some of them block the connection to the local LAN after the VPN connection is established.
Is there a possibility to turn RDM into offline mode after the web portal is opened (like it can be done for VPN entries)?
Best Regards
All Comments (2)
It would be possible to accomplish this by doing the steps below:
Firstly, you would need to go in the VPN section of your session and select Session.
Secondly, in the Settings tab, select your web browser entry
Thirdly, in the Advanced tab, enable the first option to go offline on connection
In conclusion, this should allow you to use the VPN from a website like requested.
thank you very much for your fast support. I got it working.
Best Regards
