Show OTP code on right click context for any entry that OTP can be configured
Implemented
Example:
If i create a web site session, we can enter the OTP in the entry
However, we can not see the code
It would be beneficial to have on the right click context menu to show username, password, and a choice for OTP
Right now, i have to create sub OTP connection to achieve this which adds one more entry and un needed administration.
Thank you
All Comments (4)
It don't see any problem to add this. I will add this to our todo list.
Hello!
I see this has been added! thx you!
However, when you view the OTP it is static and does not change.
So by the time you get the otp and go to enter it, the code may change as you can not see the countdown nor new code.
At that point you need to exit the view, go back and try again...and still may not make the countdown
Can this be added:
Have that field show the count down till code change and refresh the code when it does.
Basically, just like if this was an OTP entry and you view password. At that point it brings up the current code, count down, then refreshes.
You can still have the username, password and OTP fields....but have the countdown and code refresh happen in this view
thx again
Thank you for the feedback. We'll take a look at this issue.
This improvement has been completed internally and should be included starting from RDM 2020.3.0.0
Michaël Beaudin
