Powershell: Get-RDMSession: Connection not found
joffrey
Disabled
I make a simple loop :
 Get-RDMRepository |  ?{($_.Name -notlike '*XXX*') -and ($_.Name -notlike '*Temp*')} |% {
	Set-RDMCurrentRepository $_
	$s = get-RDMSession | ?{ $_.Name -like '*staging*'}
But, on many repository, I get this error:
Get-RDMSession : Connection not found.
Any idea please ??
Thanks you
'Joffrey
All Comments (4)
The Set-RDMRepository cmdlet is used to save the modification of any vault properties.
Please use instead Set-RDMCurrentRepository to switch to another vault and then add the Update-RDMUI cmdlet right after that cmdlet like the following.
Update-RDMUI
Érica Poirier
joffrey
Disabled
Hmm.. check my code. I use Set-RDMCurrentRepository
I added Update-RDMUI, no change:
	Update-RDMUI
result:
get-RDMSession : Connection not found.
At C:\ps1\rdm_staging.ps1:7 char:7
+     $s = get-RDMSession | ?{ $_.Name -like '*staging*'}
    + CategoryInfo          : InvalidOperation: (:) [Get-RDMSession], Exception
    + FullyQualifiedErrorId : 0,RemoteDesktopManager.PowerShellModule.GetRDMSessionCommand
I don't have this error on all Repo
According to the error message, it seems that some of the vaults do not contain sessions with staging as part of the session's name. You could trap these errors with the try-catch code block like this.
	Update-RDMUI
    try {
    	$s = get-RDMSession | ?{ $_.Name -like '*staging*'} -ErrorAction Stop
    catch {
Érica Poirier
joffrey
Disabled
I tested your code (and add the Name of the current repo):
I checked all repos with the error. The Staging (it's a group) exists. Some are empty, and some not..
I don't understand
