Quick Connect RDP with RD Gateway and Solarwinds Passportal integration
Hi there,
In the Quick Connect field, you can RDP to a server. Is it possible to extend this so you can specify a RD Gateway address as an additional attribute?
Also, I see that RDM supports Solarwinds Passportal, but it is quite limited. My Passportal account requires MFA. If I use RDM to access my Passportal credentials, I will get the MFA prompt every single time. Whereas if I just access my Passportal via a web browser, I only need to enter my MFA just once for that single session. Can we make RDM to only prompt for MFA for the first time, until RDM is restarted? RDM doesn't seem to save any cookies for the session and just keeps prompting MFA.
Also, can we import Passportal credentials into RDM? This doesn't seem to be a supported option.
BTW, the forum seems to have changed a bit. I used to be able to create a new topic and paste screenshots. Now, I don't even get redirected to a new page for creating a forum post. I just get a popup window on top of the current page and if I try to paste something that's in my clipboard, nothing comes out.
I'm always using the latest beta RDM x64 version.
Local data source.
All Comments (2)
Quick Connect: To accomplish this, you would need to use a template
https://help.remotedesktopmanager.com/commands_creatingtemplates.html
PassPortal: We will have a look at this, but we cannot provide any timeline.
Forum: Our forum has been revamped last week. It's completely new :)
Our web team has been assigned on it to have a look at your request.
Just a quick message to let you know that we have opened 2 separate cases for Passportal.
The ticket number are RDMW-4710 and RDMW-4711.
