The date sort is based on numbers/chars rather than actual date,
See below
Thank you for the report, we will open a ticket to take a look at this issue.
Thanks Hubert,
Is there any way I can follow on the status of this issue?
We will update this thread as soon as we have a fix for this issue.
This issue should be fixed starting from the next version of RDM.
Michaël Beaudin
Hello guys,
I don't think it's resolved. Please have a look. Version 2024.2.16.0.
I can see from your screenshot that it seems to not be sorting properly again.
We will open a ticket to fix this and keep you updated on the progress.
Best Regards,
Michaël Beaudin
Hello Michael,
Sure, thank you very much!
Hello piotrmajewski.
We've tested on our side and haven't been able to replicate the issue yet. Could you please share with us your Date Time format (the one your OS is using), as well as the exact entry type where this replicates. It would likely help us pinpoint the problem.
Jafran Majeau
