Resolved
S3 explorer issue
I have setup in my lab an S3 compatible object storage (minIO). I have tried RDM native S3 explorer with custm url, but it crashes when opening.
Then I have configured CLI(external application) session pointing to my S3 Browser (www.s3browser.com). If I run it in External display mode it works as expected. If I run it in Embedded mode, the session is opened, but the S3 menu' and buttons doesn't work.
I'm working on RDM 2020.1.9.0 beta
All Comments (14)
Does RDM crash or the session crash? Do you have any information about the crash in Help - Application Logs.
Best Regards,
Etienne Lord
Hello Etienne,
with integrated S3 explorer, the session is opened, but login to the storage fails with the error you can see in the attached screenshot.
The S3 Browser running in the embedded session has all the commands that don't work, while browsing the folders works.
thank you
Best Regards,
Davide
Thank you, we will investigate on that :)
Best Regards,
Etienne Lord
Would you be able to send us a recording of the issue using the link I sent you via Private message?
Best Regards,
Etienne Lord
Hello Etienne,
I have uploaded the video about issue with S3 Browser (embedded vs external) and S3 Explorer.
Thank you
Davide
Thank your for the recordings, I will check with the engineering department :)
Best Regards,
Etienne Lord
It seems to be missing the most important part of the exception error, can you confirm that your address is correct?
Best Regards,
Etienne Lord
Hello Etienne,
which address are you referring to?
thnak you
best regards
Davide
Sorry, make sure that you information (URL, Access Key and Secret Key) are correct :)
Best Regards,
Etienne Lord
Also, when you get the exception error, could you click on "Details" and then send in the report?
Best Regards,
Etienne Lord
Yes,I'm sure. Infact if Iaunched in external mode (not embedded), both applications (S3 browser and Explorer) are working. This address is a S3 server I'm using in my lab for other applications.
thank you.
Davide.
Interesting, we will look into it, did you send it the full error report?
Best Regards,
Etienne Lord
attached the S3 Explorer logfile. It seems that it is unable to resolve the bucket hostname, on the S3 server there isn't any bucket hostname configured. The only way to access to it is via URL https://server_name:port (in my lab it is https://192.168.254.124:9000).
In the meantime I have updated my RDM to latest release 2020.1.15.0, but the issues remains (S3 Explorer doesn't works anyway, S3 Browser via cli command works in external window, but not in the embedded mode).
Thank you
Best regards
Davide
S3_Eplorer_log.txt
Amazon seem to throw error (NameResolutionsFailure) so it doesn't seem like the error comes from Remote Desktop Manager. It could be an issue with the DNS.
The address show in the video is different from the one in your logs.
Best Regards,
Etienne Lord
Closed
