Newbie need help
phenix
Disabled
hi everyone
I'm trying to use SQL Server 2005 as the data source without success. I'm using a trial license with ver 5.0.2.0 and when I open the File|Data Sources window, I'm not given the opportunity to add a new data source. The screen allwos me to select SQL Server or Access, to Edit, or to Set as Default only.
Why? and how to fix them
Many thank
All Comments (1)
We only support SQL Server 2012+ : https://help.remotedesktopmanager.com/index.html?datasource_sqlserver.htm
Furthermore, did you download Remote Desktop Manager Free or Enterprise?
Best Regards,
Etienne Lord
