Select monitor in RDP shadow mode
simon03
Disabled
Hi Guys,
is it possible to select the monitor in RDP shadow mode if the remote client has more than one monitor connected?
All Comments (2)
Sadly, if you are using the Microsoft RDS Dashboard, it uses a specific template to launch the sessions and cannot be change, therefore the display options cannot be set to launch multiple monitor or select another monitor.
Best Regards,
Etienne Lord
simon03
Disabled
Thank you anyway!
