problem to sync OU infrastructure from AD
I have problem with AD sync. I have created a folder (organization name) in RDM and two sub folders (domain names). In each domain I have set up synchronization with AD for DC and Domain Servers. Computers objects sync with AD, but I can't sync sub OUs from AD. Everything is synchronized to the root directory created in RDM, even if Create folders from OU / containers is checked in the \ Settings connector and the appropriate level is set.
Best regads,
Martin
All Comments (1)
That being said, would it be possible for you to provide me screenshots of the configuration of your AD Synchronizer entry? These can be sent to me via private message. I will need to see "General", "Settings", "Login", "Filters" ,"Search" and "Advanced".
Also, which version of RDM and what type of Data Source are you currently using?
James Lafleur
