Custom Permissions on vault
Hi
When im trying to set custom permissions on a vault or a folder i gets this error "Unable to save the entry; invalid data sent!"
All Comments (6)
Which version of RDM are you using?
What type of data source are you connected to and which version please?
David Grandolfo
its works when we keeps "Edit information" to default but if i changes this property to any outher value it fails
Version 2019.2.22.0
Is the data source a Devolutions Password Server? If so are you using the latest version 2019.2.12.0?
David Grandolfo
yes we are using the password server as datasource
version 2019.1.20
This error will pop-up when using the latest RDM version 2019.2.X with DPS 2019.1.X.
I recommend scheduling a session with our DPS team (by sending an email at ticket@devolutions.net) to upgrade DPS to 2019.2.12 or to downgrade RDM to 2019.1.X
David Grandolfo
Thanks i have updated the DPS to 2019.2.12
