cast rdp to chosen monitors on my system
bsmokeman
Disabled
instead of specifying which monitor, or which custom resolution for an rdp session, it would be extremely useful to choose, or save a pre-determined set of monitors that remote desktop manager presents to rdp for the remote session, leaving the ability to keep your remote session full size for say 8 monitors out of 10, so I can have a live stream, or chat window up on my local pc, while utilizing the rest of the remote session for say trading charts on a redundant datacenter level rdp session.
So it will choose the next one available?
bsmokeman
Disabled
no, it would integrate more with the windows monitor subsystem, and allow multiple selection of specific monitors, and set the span, and auto-set the resolution for the remote session for those selected monitors. some of this might not be currently possible without feature requests from microsoft, however some of it should be. with a default rdp span accross monitors, you only get the "use all my monitors for this connection", for massive multi-monitor systems it might not be practical to use all monitors and would be helpful to use 3 out of 4, or 5 out of 6, etc...
bsmokeman
Disabled
btw, the monitor names presented in the remote desktop manager rdp session properties does not match the number or monitor description in windows.
I tried monitor 1, and it popped up on what windows says is monitor 5.
