monitor pre-defined profiles, or templates/split sets
bsmokeman
Disabled
if I split a 4k monitor, or even a remote rdp session into 4 quadrants, and then take 1 of the quadrants, and split it virtually into a split set, it would be great, to select the other 3 quadrants, and load the split set at will.
All Comments (2)
Do you know if it something you can do with another application? I would like to see an example?
bsmokeman
Disabled
no, never needed it before I started getting into trading, but just joined a trading group, who has a certain window set for ninjatrader. ninjatrader charts are all separate windows. it takes a ton of time to set up one chart set, and it's based on a 1080p screen size, so in order to replicate that 1080p window set, you have to replicate each chart, then size it for different markets. it would save tons of time, to have a monitor template, and be able to replicate the splits to each monitor...say 8 to 10 monitors, and if you go 4k, it becomes even more of an issue, multiply your sets times 4, for each 4k monitor.
