Vault specifier for Playlist entry
Please consider adding a Vault parameter to the playlist that can be set in RDM to allow the playlist to reference the specified vault when the playlist is executed. Each of the vaults would have RDP entries with the server name and different connection parameters to either use the VPN/SSH tunnel or connect directly without the VPN.
This will supoort RDM instances installed on user machines outside the datacenter or RDM instances installed on jump servers inside the datacenter firewall. The users would login with the same account on both RDM instances, but the vault would be different inside the datacenter firewall.
All Comments (2)
Moving to RDM forum
Maurice
I have added this to our feature request list.
Thank you
