User specific settings - Navigation pane - "icon/color" display of connection?!
Resolved
we use user specific settings with different connection types.
Is the a way to see, if an entry has specific credential settings set - directly in the Navigation view?
I sometimes have the situation, where I'm unsure, if the connection uses my personal or
inherited credentials. It's also for security purposes, to determine, if personal credentials are set correctly (used).
Is there a way to change the f.e. RDP-Icon color automatically, if there are user specific settings set?
Daniel
All Comments (4)
It is indeed possible to see if a User Specific Settings is set on entries with the Specific Settings column. Let me know if this method is suitable for your needs.
Érica Poirier
Hello Érica,
thank you for your fast feedback.
It is OK, but a different background-color of the icon, text or another optical difference would be nicer than text.
To be true - not super-important, but it would be nice.
It's like the little "play" button inside the icon, which (without additional text) says: Another person is connected - without the need to read/see text.
As said - not super important, but it would be a nice, little feature (in my eyes).
Daniel
Hello Daniel,
Thank you for your feedback.
I will transfer this thread in the Feature request section so the engineering team can have a look on your request.
Érica Poirier
The feature request RDMW-4231 has been submitted to our engineering department. Once an update will be available we will post it here.
Érica Poirier
Closed
