Move entries from my private vault to vault without exporting them
Hello
it does not seem possible to move entries between my private vault and vault (and vice versa).
I can do it only by exporting and importing but it is quite uncomfortable.
Thanks
All Comments (5)
Indeed there is no feature available to move entries from the Private Vault to a shared vault or from the shared vault to the Private Vault. Let me check with the engineering department what we can do and I will get back to you.
Instead of using the export/import operation, you can use the Copy/Paste operation from the Home menu.
What RDM version are you using?
What data source type are you connected to?
Érica Poirier
RDM Enterprise 2019.2.15.0 64bit
SqlAzure dabatase
Thank you for the information.
May I ask if it's something you want to do on a regular basis?
Could you please provide more details on the scenario for moving entries from your Private Vault to a shared vault?
Érica Poirier
No no - very rarely
Copy & Paste are perfect.
Thanks
Thank you for your feedback and glad that the copy/paste operation satisfies you.
Érica Poirier
